New thermostat issues
Old 01-04-15, 08:41 PM
A
Good evening - I installed a new honeywell rth6350d thermostat. I had an older honeywell model that was not digital - not sure what the model was.
I followed the install guide from honeywell and everything was working fine after the install. However, when I just tried to turn the heat up - nothing happened. I tried turning the fan on, still no luck.
I have a ruud heat pump - model ubha-14j10nfaa.
There was an "x" wire that I had installed on old; installed on new, then tried removing it to see if that would help.
Here are 2 pics of the old wiring and the wiring.
Any help is greatly appreciated.
Thanks.
Old:
New:
Old 01-04-15, 09:11 PM
firedawgsatx's Avatar
Welcome to the forum! Do you have function 1 set to 5 and function 2 set to 1 in the setup menu as shown on pages 14 and 15? The X wire from your old stat is not used so you can just tape that off.
https://customer.honeywell.com/resou.../69-2416ES.pdf
Old 01-04-15, 09:22 PM
Received 923 Votes on 862 Posts
Welcome to the forums.
Where did you connect the X to on the new thermostat ?
X is the common terminal and if you had it connected to the new thermostat you either popped a fuse on the control board or shorted the transformer out.
You'll need to check the control board in the air handler for a fuse. It will be a 3A or 5A flat plastic fuse like used in cars.
Old 01-04-15, 09:47 PM
A
Yes I did. I just doubled checked and the functions are set up correctly.
I originally had the x wire in with white wire or aux/e.
Old 01-04-15, 09:50 PM
A
Thanks. I had the x with the white wire in the aux/e port then I removed it.
I'll have to check the fuses. I need to figure out where everything is.
If it is a fuse, can I use a fuse from my car that matches or do I need to get any special one?
Thanks for the help so far.
Old 01-04-15, 10:47 PM
Your system would use an ATC-3 or ATC-5 fuse.
Size:  5.1 KBName:  5a.jpg
Any ATC fuse of the proper amperage will work. Available at most auto parts stores.
Old 01-05-15, 05:24 AM
A
Where is the air handler control board located? Inside or outside?
I opened up 2 panels where my air filter goes, I believe that's the air handler? And did not see any fuses similar to the ones to look for.
Old 01-05-15, 07:46 AM
Geochurchi's Avatar
Received 57 Votes on 53 Posts
What is the model of the A/H?,can you locate any wires going into the A/H?
Geo
Old 01-05-15, 08:19 AM
The board is in the inside unit. Look for thermostat wiring entering the unit.
