Fan not turning on with new thermostat
Old 01-11-15, 01:01 PM
im having an issue with the fan coming on since i put in the new thermostat. i have the following setup on wires. the thermostat in question is the Honeywell RTH6350
L=NOTHING
AUX/E=WHITE
G=GREEN
O/B=ORANGE
NOT USED=BLUE
Y=YELLOW
R=RED
RC=BRIDGED FROM R
All of the wires on my heat pump unit correspond to the wires listed above. the white wire is hooked to w2 in the panel. other than that they all are exact as they say.
I know my old thermostat had auxillary and emergency heat settings so i have the settings on my thermostat set to 5 for heat pump with auxillary. also its set for electric. im just getting no response from the unit and im not sure what else i can do.
Old 01-11-15, 02:23 PM
firedawgsatx's Avatar
Welcome to the forum! Confirm you have function 3 set to 1.
Old 01-11-15, 02:28 PM
Thank you for the welcome!!!
with fuction 1 set to 5... my functions jump from 2 straight to 6 skipping function 3.
Old 01-11-15, 03:06 PM
What do you have function 2 set at?
Old 01-11-15, 03:11 PM
Geochurchi's Avatar
Received 57 Votes on 53 Posts
5 should be set to9 any type of electric system,you did use fresh batteries.
Geo
Old 01-11-15, 03:23 PM
Function 2 is set to 0. Also Function 5 is not showing up either with my function 1 preset at 5. And yes brand new batteries
Old 01-11-15, 03:31 PM
Received 932 Votes on 869 Posts
It sounds like you missed the advanced programming steps.
The advanced start on page 13.
honeywell request form 3D69-2416ES.PDF
1---> 5
2---> 0
3---> 1
5---> 9
6---> 5
8---> 9
Old 01-11-15, 03:35 PM
I went through them and adjusted everything acccordingly. I know i have a heatpump and i know it has the emergency heat and auxillary heat options. also it has the heatstrips for defrosting as well
Old 01-11-15, 03:37 PM
Just checked my field notes for this thermostat. It is normal for function 3 to not show up and then skip to functions 6 and 8 when setup for a heat pump with auxiliary heat. Do you have functions 6 and 8 set to 9?
Old 01-11-15, 03:42 PM
yes function 6 is set to 9. from there it skips to function 13.
Old 01-11-15, 03:46 PM
You might have a defective thermostat. I have had a few defective right out of the box. For a test you can turn off power to the air handler. Remove the wires going to the R and G thermostat terminals. Twist the ends of the two wires together, turn power back on and see if the fan will come on.
Also, double check the G wire at the thermostat and inside the air handler to make sure the connections are solid.
Old 01-11-15, 03:54 PM
i twisted the two wires together and nothing yet... i did turn the power back on. do i need to wait at all? i know it was working fine this morning before the old thermostat was removed.
Old 01-11-15, 03:59 PM
Since the fan did not start with the R and G wires twisted together it sounds like you have a problem other than the thermostat. You probably have a blown 3 amp automotive blade type fuse in the air handler. When you changed the thermostat was the power shut off for the air handler? In your first post you stated the fan wouldn't come on. Did the condenser outside come on when you set the thermostat to heat?
Old 01-11-15, 04:02 PM
yes when i changed the thermostat i shut down the power going to it. also no when i switch it to heat or cool i get absolutely nothing. i checked outside to there is nothing turning on at all
Old 01-11-15, 04:05 PM
Ok, I would check for an automotive type fuse in the air handler to see if it has blown.
Old 01-11-15, 04:12 PM
ok ill check it out as soon as i get a chance. thanks for your help!
Old 01-11-15, 04:15 PM
If you get a chance post the model number of your air handler so a wiring diagram can be accessed to check for a fuse.
