Electric wall heater questions
Old 01-22-15, 12:31 PM
C
Hello,
I am a new member to the forum, and have greatly benefitted from many of the topics and threads thus far, but I am having some problems finding the answers to a few questions.
I am currently remodeling my new home in Seattle. I have upgraded my main panel and have rewired 90% of the home. The plan is to install either a Cadet or King electric wall heater in each bedroom, living room, and kitchen - and do electric floor heating in the bathrooms.
Questions:
1. Is there any benifit to using 120V or 240V electric wall heaters?
2. Can I have two heaters of different wattages' hooked to one t-stat? (2000W in living room & 1000W in the Kitchen)
3. Is it possible to connect a "smart" t-stat (low voltage) to my electric wall heaters with the use of a relay/transformer? similar to the below image, except for electric wall heater, not floor heating.
Name:  Screen shot 2015-01-22 at 3.25.39 PM.jpg
Old 01-22-15, 01:04 PM
Geochurchi's Avatar
Received 57 Votes on 53 Posts
Hi, the higher voltage heater will require a smaller conductor size for the same wattage,also the relay would be fine for 2 different wattages same voltage as long as the amperage does not exceed the rating of the relay .that Tstat should also be fine.
Geo
Old 01-22-15, 10:43 PM
Received 932 Votes on 869 Posts
Welcome to the forums.
Like Geo mentioned 240v heaters require smaller wiring and they also balance the load on the electric service better.
You're not going to put a nest in every room..... you'd need a small fortune.
Keep in mind..... do not install thermostats over electric heat strips. Best to put the strips on the outside wall and t'stat on an inner wall.
