Thermostat wiring
Old 01-24-15, 09:36 PM
T
Thermostat wiring
I had new 5 ton 2 stage package heat pump system installed and the old had a 7 wire set up at thermostat..C,E,W2,,O,R,G,y1.
The new system has a low and a high cool y1/y2 along with the w1/w2 heat
,comes with the R,O,G,C.
It has a 8 wire set up on diagram and im trying to figure out if i need to run a new wire for the y2 or if i can continue using it with the 7wire set up.
I have a new thermostat to look at wiring but need to know if ill need the other wire added.And if the new thermostat has to have both y1/y2/ two stage
I also jumpered the E with the w2 for emergency heat..
The new thermostat im wanting to install (RiteTempt 6030 flush in wall type) has a jumper inside that when u want emergency heat u change the jumper -can i use that E wire then for y2?
-any info is appreciated
Old 01-24-15, 10:01 PM
Received 909 Votes on 849 Posts
Y2 is second stage cooling. So you wouldn't connect that line to a heat terminal.
With multiple stages come multiple wires. Looks like you'll need that 8th wire.
Old 01-25-15, 05:42 AM
Geochurchi's Avatar
Received 56 Votes on 52 Posts
Looks like you have the option of using the wire from the C terminal for the Y2 connection if you install batteries,remove the wire from the C terminal on both ends and land it on Y2 at both ends.
Just a thought
Geo
Old 01-25-15, 09:05 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Are you referring to the air handler diagram?
I would wire as shown on page 20 and add Y2.
Connect the unused wire to Y2 at both ends.
Old 01-26-15, 01:04 PM
T
im refering to this set up -page 25-2 STAGE-but i dont see 8th wire on it i do have a O wire .also see it has optional power .Also to get E heat it says i can change inside jumper page 27
thanks
Old 01-27-15, 05:21 AM
Houston204's Avatar
If you have a heat pump you are looking at the wrong diagram. You will greatly increase the heating bill if you connect a heat strip to W with a heat pump. This would bring in electric heat for stage 1 heat.
I don't think that I have ever seen a roll of 7 conductor thermostat wire. Chances are high that you have 8 conductors pulled to the stat. You do not actually need 8 conductors.
Old 01-27-15, 08:11 AM
T
the older pump had 7 wires-both ends too- here is a pic of both ends.
It was NOT a 2 stage .and no heat kit was with it either.
-diagram to new shows 8 wire..the chart on the right side applies to it.
-so your saying even though i have 2 stage heat now and 2 stage cool not to go by the 2 stage heat cool diagram on page 25?(its for non heat pump systems?)
also on email im now being told its not compatable..they have no phone support
Old 01-27-15, 12:31 PM
Houston204's Avatar
Connecting to W can cost you several hundreds of dollars per year with a heat pump.
