Sylvania (Quality Craft) heater issue
Old 01-29-15, 12:02 AM
K
Picked up a 2000w convector heater with built in thermostat 2 years ago when costco had a great deal on them. Knowing it had a built in thermostat I still wanted to use my wall thermostat. Here is my problem, once the heater reaches the desired temperature of the wall unit it shuts off(so far no problem) but once it turns back on again to heat up , the memory on the built in thermostat is reset with screen light flashing and unless I set time and date it won't function. This also happens when I lose power. All my wall thermostats in the house keep their desired settings but the built in thermostat needs to be setup again. Does anyone know what causes this? Is it a wiring issue? I live in Mtl and at -30c sometimes I can't have the heater off for too long. Is there a way to maybe bypass the built in thermostat?
[ATTACH=CONFIG]45728[/ATTACH]
Old 01-29-15, 09:09 AM
Received 909 Votes on 849 Posts
Welcome to the forums.
I need a model number for your unit. If it's the SYACP-2000 then I have some info on it. The following is an incredible excerpt from the manual.
I call your attention to the highlighted area where it claims it needs to be connected to a wall switch or thermostat and yet it already has a thermostat built in.
So there is a lack of communication here as you can't have two thermostats working together.
Old 01-29-15, 09:25 AM
K
Hello, thanks for looking into this. Just looked it up and it is the SYACP-2000 model. Let me know thx.
PS. Just spoke to Sylvania customer service and was told that it was totally normal. If true well that is a bad design flaw. Let's say I go on vacation for a week and there is a power loss the first day and comes back right away my heater won't work for the rest of the week since I need to redo the time and date settings. Whata joke
Old 01-29-15, 10:09 PM
I don't have the internal diagrams for that heater but if you want to remove the cover and post a few pictures we may be able to bypass the internal programmable thermostat.
Old 01-30-15, 05:21 AM
D
Received 1 Vote on 1 Post
If this is normal operation, then maybe it's time to take advantage of Costco's return policy and find something else, as this unit seems to be borderline useless for your situation.
Old 01-30-15, 09:20 AM
K
I'm not sure they'll take it back after 2 years!
Old 01-30-15, 09:23 AM
K
Here is a picture of the inside wiring.
Old 01-30-15, 09:34 AM
Nice picture. I need a second one of the entire heater so I can see the other end of the heating element. This conversion should be pretty easy.
Old 01-30-15, 02:35 PM
K
Here you goName:  image.jpg
Size:  29.8 KBName:  image.jpg
Size:  22.3 KBName:  image.jpg
Old 01-31-15, 11:21 AM
I'm not sure how power gets to the heater although it looks like that white box where the ground wire is connected. The two red arrows show the 240v heater element connections. One is white the other is black. Your incoming power wires will now connect directly to the element with no internal thermostat connection.
This wiring modification is to allow the heater to work with an external thermostat. I am only offering the connection method to do this. I'm not condemning or condoning the modification.
Old 01-31-15, 04:48 PM
K
Thank you Pjmax, followed the wiring you posted and worked like a charm. No more useless built in Thermostat. Wish I had known about this forum earlier.
Old 01-31-15, 07:03 PM
Your good pictures made it easy. Well done
Old 02-01-15, 08:52 AM
D
Costco's published return / repair policy promises they will - and my Costco loving friends claim it would be dead easy to return .
It may be worth an inquiry if that'd solve your problem.
Old 02-01-15, 09:10 AM
I would have pushed for an exchange also but I investigated that unit and it doesn't appear to have the ability to hold memory on a power down. It has me a little confused because if you read the warning that comes with the heater, (see post 2) it tells you to connect to an aux. thermostat or wall switch.
