Wiring help!!! Fuse to breaker
Old 02-13-15, 08:21 PM
T
I recently got a new furnace. My old furnace is a Coleman 3400-818 electric furnace. I just bought the Alpine AHEB12D. I live in an old trailor. The issue is the old furnace is a fuse furnace, And the new furnace is a breaker furnace if that makes any sense. I have no clue how to wire this. I donít know if I can remove the jumper bar and directly wire into the 4 slots beside it? because Iím a double circuit and the jumper bar is for single circuits. ( sorry for the dirt and dust in the old furnace, recently moved in and a smoker lived here before me. ) If somebody could tell me which wire goes into which post? Iím really confused. (note, i know where the ground wire goes)
Name:  Old furnace.jpg
Size:  30.8 KB Name:  New furnace.jpg
Old 02-13-15, 09:15 PM
Received 932 Votes on 869 Posts
Welcome to the forums.
You do have two circuits feeding your old furnace..... correct ?
Looking at the fuses.... what is their size from top to bottom ?
Old 02-15-15, 05:20 AM
Geochurchi's Avatar
Received 57 Votes on 53 Posts
Hi, it's hard to tell from the pics ,how many feeds are coming into the old unit? Can you post a pic of the new unit wiring Dia.?
Geo
Old 02-15-15, 06:56 AM
A
Received 36 Votes on 32 Posts
Looking at the specs that size model is "Approved for Single Branch Circuit Service Only." The right way to do it is to run a new 6 gauge cable back to your electrical panel. Removing the jumper would void the warranty.
Old 02-15-15, 07:14 AM
Good call Astuff
Unfortunately he is correct and you may need to run a new power cable.
Alpine Home Air Products: Contractor-grade furnaces
Old 02-15-15, 12:33 PM
Geochurchi's Avatar
Do you have any spec's on the old unit?can you determine what size cable is feeding it now, it must be #6, and jumpers can not be removed as previously stated.
Geo
