Carrier heat pump won't shut off
Old 02-21-15, 07:39 AM
B
I have a complete carrier system heat pump but I set thermostats at 70 degrees and when home reaches temp furnace continues to run and air intake read 95 degrees and home gets really hot wHat can I do?
Old 02-21-15, 08:07 AM
Received 913 Votes on 853 Posts
Welcome to the forums.
The thread you posted on was a different problem than you are having.
Does the compressor unit outside stop at the correct temperature ?
Does your heat pump system have emergency or supplemental electric heat.
Have you tried turning the thermostat to OFF when the temp rises over 70 degrees ?
