A.C. Transformer
Old 02-24-15, 04:52 PM
D
Question A.C. Transformer
Hey guys budgets at a end for repairing my new home was told my a.c. transformer was bad so picked up a new one but the new one is different but they said it was compatible, I'm posting pics of both the old still hooked up and the new one, can someone please tell me were to wire each wire.
Size:  32.8 KBName:  11006204_10200349943148976_1431153021_n.jpg
Size:  28.2 KBName:  11004401_10200349953309230_314073368_n.jpg
Size:  40.8 KBName:  11008942_10200349941188927_1974042157_n.jpg
Old 02-24-15, 05:26 PM
D
Lightbulb Possible solution? Someone Please Verify it for me though.
Had a friend that knows more about this kinda thing look over it and he came up with this but we both wanted to post it just to be sure that nothing was missed.
Old 02-24-15, 05:50 PM
Received 924 Votes on 863 Posts
Welcome to the forums.
Here is a visual depiction.
Red and black from HV side get capped off. All connections can be made with wirenuts.
Your chart looks good.
Old 02-24-15, 05:59 PM
D
Thank you very much I will be wiring it in tomorrow afternoon. Appreciate the double check. Can't wait to have heat again lol.
Old 02-24-15, 09:51 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I recommend adding a low voltage blade type automotive 3 amp fuse if you have gas heat or a 5 amp fuse if you have electric heat (air handler) to protect the 24 volt circuit.
Old 02-25-15, 04:38 AM
D
We did add a 5 amp fuse wasn't the auto type tho we added the tube style as we had a holder for that style.
Old 02-25-15, 05:00 AM
Geochurchi's Avatar
Received 57 Votes on 53 Posts
That should be fine------------
Geo
Old 02-25-15, 05:27 AM
Houston204's Avatar
I agree. That should be fine.
Old 02-25-15, 04:44 PM
D
Thanks guys heat works not used to the fan outside running with heat tho....is that normal?
Old 02-26-15, 12:17 AM
I'm guessing since you posted in the heat pump forum that you have a heat pump system.
The condensor fan will run when in heat mode. It may temporarily stop when the unit goes into the defrost mode.
