Heat pump condenser/compressor not coming on in heat mode
I have a heat pump and the condenser/compressor will not come on in heat mode, only the auxiliary heat strips are activated. The condenser/compressor will come on in A/C mode but not heat mode. I have a new Carrier thermostat from my local utility and the condenser/compressor is receiving the signal in heat mode. Any ideas? Are there known problems with newer thermostats and 30 year old units (Amana)?
Welcome to the forums.
The heat pump and the air conditioning both work the same way. The only difference is when in cool mode a reversing valve is activated.
It sounds like your thermostat wasn't programmed for heat pump operation with back up heat.
Pete, I just talked to a HVAC friend and he suggested I run the heat on emergency only. When I did the condenser/compressor came on. There is a wiring problem with the thermostat. I will call the technician tomorrow.
It's definitely wired wrong. Putting the thermostat in emergency mode is supposed to lock out the condensor from running.
