Heat pump system switching to aux
Old 03-10-15, 03:47 PM
I installed a new Honeywell RTH6580WF stat and have the functions set properly. If I try to raise the inside temp 2 degrees or more it switches to aux heat. From what I understand, this can't be adjusted at the thermostat level. Is there a mistake in the heat pump wiring or settings? It was installed a little over a month ago.
Old 03-10-15, 04:40 PM
Houston204's Avatar
Received 90 Upvotes on 83 Posts
This function cannot be adjusted with that thermostat.
It is less expensive to keep the thermostat at one heat setting since a 2 degree demand will bring in the expensive heat strips.
You can take advantage of the programmable thermostat in cool mode to see some savings but not in heat.
Old 03-10-15, 05:00 PM
So the only way to correct this problem is to replace the thermostat? There isn't a setting on the heat pump unit that can be adjusted?
Old 03-10-15, 07:01 PM
Houston204's Avatar
Your options include set the stat to hold 1 heating set point (no setback), replace the stat or disconnect the Aux/E wire at the stat.
I wouldn't consider the third option because emergency heat is the same terminal.
Old 03-10-15, 07:41 PM
Ok thanks for your help. I'll probably replace it. Is there a comparable thermostat you can recommend? I don't need something as high tech as a Nest but would like it to have wifi.
Old 03-10-15, 08:49 PM
Houston204's Avatar
It is harder to view configuration options on many new thermostats since they often now configure with language instead of codes.
I tried looking into the Redlink VisionPro since I believe that I have seen this option when installing them but I do not see stage 2 options in the pdf's that I downloaded. I am not sure that it would meet your specs anyway since it is not wifi. It would require a separate gateway.
Nest makes a great lookin thermostat. I installed one today for a homeowner.
I still prefer the Honeywell Prestige IAQ.
You might read this post before deciding that a Nest thermostat's swing is able to meet your specs...
http://www.doityourself.com/forum/th...le-review.html
I will see what else I can bring up.
