Carrier heat pump energy useage question
Old 04-06-15, 05:44 PM
B
hello new here and have a question, I had installed a carrier heat pump comfort series 25HBB, in summer my electric bill is really efficient, but winter bills are really high, any ideas, I am not sharp at all on heating and a/c issues, thank you, beefheart from ohio
Old 04-06-15, 08:35 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
You can setback the temperature when you are not occupying that area in cool mode but taking advantage of a programmable thermostat in heat mode will greatly increase the amount of electricity that is used.
The thermostat will usually energize the expensive electric heat strips when a demand greater than 1 degree is present in heat mode.
What thermostat are you using?
We can double check wiring and configuration settings.
Old 04-07-15, 05:00 AM
B
thanks for the fast reply, will post the brand of thermostat later when I get back home, I program it to a lower degree when not at home or at night while sleeping
Old 04-07-15, 08:15 PM
B
its a programmable honeywell
Old 04-07-15, 08:30 PM
Houston204's Avatar
That narrows it down a little bit.
Gonna need more information.
Old 04-07-15, 08:43 PM
Received 1,324 Votes on 1,224 Posts
I started a new thread for this topic as it had nothing to do with the thread it was attached to.
Sorry for the confusion. Sent the OP a PM on the split.
