Compressor Level?
Compressor Level?
Hello,
Just had a 5 ton heat pump system installed.
My question is: The compressor is not level and tilts noticeably to one side.
Is it a cosmetic issue or should the strain on bearings in the motor or other matters dictate correction?
Thanks,
flbuild, central florida
Thanks,
It must be level or you could have a lubrication problem in the compressor with oil running to one side of it.
Geo
Geo
yikes, I better get mine leveled up...but then it's been running for over 10yrs at about 5-10 degrees out of level. Gotten worse over time, prolly the gophers diggin' under the slab. But yeah, I think I'll go correct that next time I get a few min. of spare time some time in '16, I'm hopin'...
