Electric wall heater in bathroom
Received 0 Votes
Wanting to replace original wall heaters from the 50s that do not work, but there is electricity (110) to them. What, if any, insulation and caulk could be used to try and seal the wall from the heater box that will need to be replaced.
Thank you.
Thank you.
Any type of silicone caulk could be used to seal the cabinet to the tile. The problem is going to be to find one that fits in the same place.
I had originally thought you had tile. You can probably add a piece of 5/4's (1" thick) to each side and then add some molding around the heater to trim it up.
