Goodman and Honeywell - Auxiliary Heat Always On
Old 12-01-15, 11:53 AM
R
Question Goodman and Honeywell - Auxiliary Heat Always On
I have a Goodman air handler unit (Mod # AWUF361016BA) and heat pump. I've tried two different thermostats, the present one being a Honeywell RTHL3550. With both thermostats, whenever I turn on the heat, the auxiliary heat comes on within a minute or two. No matter the temperature I set the thermostat to, even when the set temp is within a degree of the thermostat house temp, the heat strips come on. Since this has been the case with two thermostats, I'm thinking the thermostat wiring is not correct. I'm including some pics for verifying the wiring. I would sure appreciate it if someone could verify this wiring or give me some pointers. Last winter's power bills were horrendous.
Here are pics for more detail:
Air Handler Details
Air Handler Schematic
Honeywell Thermostat
Honeywell Thermostat Wiring
Thermostat Wiring at Air Handler
Old 12-01-15, 01:06 PM
On the Honeywell RTHL3550 make sure the settings are correct:
Function 1 is set to 5.
Function 2 is set to 0.
Function 3 is set to 1.
Function 5 is set to 9.
Old 12-01-15, 04:13 PM
R
I don't have all of those functions available. Here's what I have:
Function 1 - 5
Function 2 - 0
Function 6 - 9
Function 12 - 0
Function 14 - 0
Old 12-01-15, 06:37 PM
Received 1,399 Votes on 1,296 Posts
Your picture of the base shows E and AUX as a combined terminal.
The 3550 programming shows two separate terminals.
Have you gotten the stats and bases mixed ?
Old 12-01-15, 10:05 PM
R
No that's the correct base. The previous thermostat I tried was a Honeywell RTH2410. Different bases.
Here's the wiring page from the Installation Guide.
Old 12-01-15, 10:56 PM
I'm trying to find that exact booklet. None of the online manuals match that one. They show different wiring terminals and different programming. I even looked up the D model. It looks like the printed manuals were updated but the online ones were not.
Try disconnecting the white wire at the stat and see if the electric heat stays off.
