Help wiring new Heat Pump thermostat (Hunter 44760)
Received 0 Votes
I am trying to connect a new thermostat to replace an ancient mercury switch thermostat. I have a Day and Night, 4 ton heat pump, model# 542D048HP, product number 542DBX048000AAAF with electric auxiliary heat strip. The new thermostat that I have is a Hunter model 44760.
The existing thermostat wiring is:
Y- Yellow
RH jumpered to RC - Red
G - Green
W1 - White
W2 - Blue
Connections at the heat pump low voltage terminal are:
Y- Yellow
R - Red
W1 - White
W2 - Blue
G - Green
The terminals on the new thermostat (Hunter 44760) are:
G - Fan Relay
C - common?
L - System Monitor
O - Reversing Valve Cool
W2 - Auxiliary Heat
B - Reversing Valve Heat
E- Emergency Heat
R - 24V supply
Y1 - Compressor Stage 1
I have tried to contact Hunter for help and didn’t get any answers that helped out. If anyone can let me know how I should wire the new thermostat or if I need to get a different type of thermostat I’d greatly appreciate it.
Y- Yellow
G - Green
W1 - White
W2 - Blue
Y- Yellow
R - Red
W1 - White
W2 - Blue
G - Green
G - Fan Relay
C - common?
L - System Monitor
W2 - Auxiliary Heat
E- Emergency Heat
R - 24V supply
I don't see a O/B terminal on your existing stat. Are you sure about the model # you gave?
Just to clarify the furnace/air handler is the inside unit and the heat pump is the outside unit.
Received 0 Votes
I don't see an O/B terminal. Here are the terminals that are in the unit:
R
P1
Y
W2
C
P
W1
G
I'm trying to post pictures of inside as well as the schematics that are glued to the covers.
R
P1
Y
W2
C
P
W1
G
The only two I don't recognize are P1 and P. I think what you have is a standard package unit with either natural gas or electric heat strips. That being said, you need to return that stat. I would recommend a Honeywell 6000 series or better. Hope this helps.
They probably used W1 as the reversing valve connection and W2 as backup electric.
This looks to be the manual for your unit....
hvac partners/docs/1009/Public/00/40542DP2-A.pdf
In looking over the schematic quickly..... your stat should work however the stat requires a C connection to the unit.
Are there any spare wires in the thermostat cable ?
Y- Yellow
R - Red
W1 - White
W2 - Blue
G - Green
G - Fan Relay - GREEN
C - common? - ????? - NEEDED
L - System Monitor
W2 - Auxiliary Heat - BLUE
B - Reversing Valve Heat - WHITE
E- Emergency Heat - JUMPERED TO W2
R - 24V supply - RED
Y1 - Compressor Stage 1 - YELLOW
These are my tentative connections.
Y- Yellow
R - Red
W1 - White
W2 - Blue
G - Green
L - System Monitor
Wow, page 11 paragraph B states that a conventional thermostat will control this heat pump.
Energizing G and W1 runs the compressor, blower, and puts the reversing valve in the heat position.
Received 0 Votes
PJmax
I don't think there is an extra conductor in the bundle. I will tear it apart tomorrow and check. I know it will not be easy pulling in another cable if there isn't a spare conductor. If I did pull in another wire and connected everything like you have mentioned. What risks do I run if it isn't correct?
If you don't have an extra wire than you'll need to switch to a battery operated thermostat that doesn't require a C connection. Unfortunately..... all those cool looking blue ones that are always lit require the C connection.
The service manual carries a date of 1978 on it so that unit is fairly old.
Thanks Carlos... that was the thing that was bothering me. That's why I labeled my wiring tentative. You're right..... B is powered when in heat mode.... not just when calling for heat.
#22
Received 0 Votes
What would be an example (recommendation ) of a 2 stage conventional thermostat?
After looking at the wiring path for my thermostat wires it isn't going to be pretty. Have you heard of (and will it work) add-a-wire for thermostats?
#23
The Honeywell FocusPro TH6220D, The VisionPro TH8321R, The VisionPro TH8320R, Can be configured for conventional or heat pump so any of these would work. (I like the 8000 series and higher).
The are Honeywell WiFi thermostats that will also support your application.
RTH6580WF, RTH8580WF, RTH9580WF.
Search Results for honeywell wifi at The Home Depot
