Heat Pump - Outside compressor not working/fan not spinning - red lights?
Received 0 Votes
I've got a Trane XL20i heat pump - temps have dropped into the 30s overnight and I noticed that house wasn't heating up. When I looked at our outside unit, I noticed the fan wasn't spinning and I couldn't hear the compressor running. I opened up the panel and noticed 2 red lights flashing - the top one(purple circle) flashed 7 times, and according to the manual, this meant a "Low Pressure Cut Out Fault" and the recommendation was to power cycle the unit. After a power cycle, the light stopped blinking, and both the fan and compressor now run. Heat is restored!
However, the 2nd red light (red circle) is still flashing 9 times and I can't seem to find anything in the manual about this led.
Any ideas?
Any ideas?
