Ceil Heat Wall Heater Basement, need some advice?
Received 0 Votes
Good morning all.
I just finished off a portion of my basement for my boys to have a hang out place to go. Just drywall, nothing else.
The home is 40 years old and in the basement are two Ceil Heat wall heaters (240v). They seem to work and work well, put out some heat but they only stay on for about 3-5 minutes then shut off. Which I'm assuming because the thermostat is inside the unit it heats up and turns off before actually heating the room.
My question is this, do you think I would be able to add corded thermostat to this heater to distance it away from it to allow it to keep running longer? I'm contemplating just removing it and putting in baseboard.
The heater has a blower/fan inside as well, which I really liked to really move the heat.
Thanks for any suggestions.
Spankey
Spankey
You can't modify the thermostat circuit with an external one without knowing how the unit is setup/wired.
That unit should not be short cycling. It is because the heat is getting to the thermostat OR a safety stat inside the unit is sensing high heat. These units need to be dust free and the fan working to operate properly.
You would need to power the unit down.... remove the front service cover.... take a few pictures and post them for us. You may also find the model number inside the unit.
Two strange items here..... you said both heaters have the same problem which would be unusual for two thermostats to fail at the same time and I cannot find anything on Ceil Heat wall heaters even with the model number.
It's up to you. Let me know if you need any further help. Those units are pretty expensive to replace.
