Help with fuse
Old 02-28-16, 05:04 AM
G
Help with fuse
Well add another to the ranks of heat pump thermostat replacement fail. I have no power to the thermostat and the fuse is blown. The unit is old and I would like to replace the fuse to see if there is a bigger problem or not. What are my chances of finding this fuse at home depot? I think it is a 3.2/10 Amp. Could I upgrade to a modern type fuse?
thanks for any help
Size:  7.5 KBName:  GetAttachment.jpe
Old 02-28-16, 05:21 AM
Received 128 Upvotes on 113 Posts
Any auto parts store will have them.
Old 02-29-16, 07:58 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
Grainger has this fuse. The item number is 1CK54.
Old 02-29-16, 09:42 PM
Received 3,949 Upvotes on 3,542 Posts
If you can get to the wiring on the back of the fuseholder you could upgrade to a newer style fuse and holder. Even an ATC fuse would be a cost effective upgrade.
