Goodman aruf blower not turning off in heating mode
Blower shuts off in cooling when tstat is satisfied ,but not in heating? Could this be a sequencer problem.
If it turns out to be the sequencer.... take pictures of the wiring so that it gets reconnected correctly. It's very easy to get the wiring mixed up.
It could also be a thermostat B terminal issue.
Have you replaced the thermostat recently?
Is a wire on the thermostat B terminal?
The B terminal is energized the entire time the thermostat is in heat mode regardless of the temperature setpoint.
The sequencer is the most likely cause if the thermostat has not been recently replaced.
The B terminal should not have a wire connected to it at the stat. If the thermostat has recently been replaced it is very possible that this is the issue.
