Heat pump: time delay relay issue
Old 04-24-16, 11:35 AM
W
My air conditioning stopped working and I think it's the time delay relay. Also it looks like one of the capacitors on the relay might be bulged. I don't know if I'm skilled enough solder it
Old 04-24-16, 11:38 AM
CasualJoe's Avatar
Received 175 Upvotes on 158 Posts
A bulged capacitor is a bad capacitor. If you cannot replace it yourself, call for service.
Old 04-24-16, 12:53 PM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
I moved your thread to the heat pump forum.
The time delay relay is usually a sealed module with two wires that goes in the low voltage circuit to the contactor.
You may be looking at the defrost board.
A picture of what you are working on would be very helpful. http://www.doityourself.com/forum/el...-pictures.html
A make and model of the heatpump would be helpful too.
