No power to thermostat - Any advice before I call an HVAC person?
Old 09-08-16, 04:58 AM
We haven't used our heat pump for the last couple of months and just decided to install a new thermostat (Nest). But for some reason there is no power coming into the new thermostat. It's not an issue with the thermostat installation. There just is no power coming from the heat pump wire. We have a Genesis Climatemaster heat pump. Before I call an HVAC person and spend that money, is there something I can check to see why no power is coming through? (The heat pump is turned on at the breaker box). Is there a fuse that I can check? I don't know where to find the fuse if there is one and the owner's manual doesn't help. I'm pretty ignorant about this sort of thing and would appreciate any help. Thank you.
Old 09-08-16, 05:46 AM
Did you turn off the power to furnace before you changed the stat? If not you probably blew the fuse on the control board.
Old 09-08-16, 06:05 AM
An electrician installed the thermostat, so I don't know if he turned things off first. Is there any way to check the fuse on the control board?
Old 09-08-16, 08:32 AM
Yes, remove panel on the blower section on the furnace. If you give us the model number of the furnace we can be more helpful.
Old 09-08-16, 09:13 AM
Received 1,472 Votes on 1,360 Posts
In a case like this... a make and model number are the first thing that should be posted.
Old 09-08-16, 09:15 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
The model number of this geothermal unit is usually on the front panel or the left of the front panel.
http://www.climatemaster.com/commerc...ct-Catalog.pdf
I don't remember a fuse on those units but the diagrams in this Genesis GS series manual appear to have a CB3-4A .
Old 09-09-16, 12:23 AM
CB3 is a 4A circuit breaker.
The diagram shows it as an auto reset type but it may have a push button reset.
