Need help installing thermostat - Honeywell RTH3100C
Can someone give me the proper connections for my thermostat? The a/c / heat pump is a Rudd model (-AKA, -ALB, -AMB).
There are four wires coming from the wall (red, white, green, yellow).
They were connected to the old White Rodgers model 1F80-361 as follows:
G - green
Y - yellow
W - white
RC - red
RC to RH jumpered
The new Honeywell RTH3100C has the following connections available:
E, Aux, Y, G, O, L, R, B, C
G - green
Y - yellow
W - white
RC - red
RC to RH jumpered
The blue wire is spare wire which you might need for a new stat. The stat you bought is for a heat pump. I would take it back and get an RTH 6000 or higher.
Yes it is. I already have it hooked up and running the a/c. I tried to run the heat, but it's either not heating, or it's too warm to verify function. It was 78 deg in the unit here in Florida. I set it to 81, but it never got warmer.
Right now, this is the way I have it hooked up:
Y - yellow wire
G - green wire
R - red wire
Aux - white wire
E and Aux jumpered
blue wire left unconnected
I ran it with and without the E to Aux jumpered. It seemed to make no difference.
I'll admit I don't know if the unit has a heat pump. I don't know how heat is provided.
Y - yellow wire
G - green wire
R - red wire
Aux - white wire
E and Aux jumpered
You need to connect the blue wire to C terminal on the stat. We will need the model number on the furnace to tell you where to connect the blue wire at the furnace.
I don't believe anyone has a conventional furnace in South Florida. Certainly no gas or oil hooked up to our condominium complex.
