Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Heat Pumps and Electric Home Heating
Reload this Page >
Need help wiring a heat only thermostat for electric fan forced garage heater
Old 12-11-16, 07:11 AM
C
I am using a Honeywell TH1100DV Heat only thermostat with a QMark MUH072 7.5KW electric fan forced heater. The thermostat connects to the "C" and "G" terminals on the heater. I am not sure which terminals I use on the thermostat. My options are "W" Heat relay, "C" 24V Common and "R" Power.
Old 12-11-16, 08:35 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Are you referring to a 7 amp fan center that someone field installed to control a small electric heater?
If R is power and nothing is connect to R then we don't have power at the stat?
If the stat is using batteries, I can see only using R and G at a fan center ( If we are talking about a fan center).
On a Fan Center the G terminal closes the relay to send power to your unit.
This relay normally energizes a fan but if you wanted to control a 27 amp heater this relay could energize a contactor to power that heater.
Post some pictures of your wiring.
Old 12-11-16, 09:44 AM
C
The heater has a contactor and 24v transformer for controls. I'm attaching a picture of the heaters Control Terminal Board (See figure 5) and the terminals for the Thermostat. Thanks!Name:  Thermostat.jpg
Size:  35.4 KBName:  Heater Control Terminal Board.jpg
Old 12-11-16, 09:57 AM
Houston204's Avatar
I cannot read the heater diagram.
Cropping the image before posting will often result in a better picture.
Many manuals have a manual number on the bottom of the front page.
It may be possible for me to get the manual in digital format with this number.
Old 12-11-16, 10:13 AM
Received 1,105 Votes on 1,025 Posts
Looks like just a closure is needed on R and W1.
marley/system/files/node/field-file//5200-11106-001_final.pdf
