Coleman mobile home hp wiring
Received 0 Votes
Has anyone ever wired one of these up? It is somewhat confusing. Looking at the schematic should I be wiring the yellow from the thermostat to the outside and to the air handler or from the t-stat to the air handler only?
Thank You!
Thank You!
You will have one yellow wire from stat and one wire from the condenser, which could be any color. Most of the time its red. Post a pic of the stat wires at the furnace.
Model numbers would be of assistance. You posted in the heat pump section. Is this a heat pump?
Heat pumps usually have this setup but model numbers would let us be more accurate...
