At what PSIG should the thermal overload switch shut down the compressor?
Old 01-24-18, 12:39 PM
A
Bosch/FHP model EM028 single stage 2.3 ton heat pump, vertical, top discharge. A tech was out and wrote on the invoice that the compressor does not go into overload until 600 PSIG.
As far as I know the compressor thermal overload switch is just a bi-metal immersed into compressor oil, so it operates on the temperature of that oil and not the pressure in the high pressure line. I guess there should be a corresponding value. The tech does not know it and would not call the factory even though I already paid him to come out and diagnose.
Bosch tech support is only for techs and they will not talk to the homeowner. This info is not in the installation manual. So I am stuck not knowing if that overload switch is good or not.
Thanks
Old 01-24-18, 01:56 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Sounds like the thermal overload is good to me.
Old 01-24-18, 02:49 PM
A
Thanks Carlos,
Can you be more specific.
At what oil temp do you expect the compressor to overload?
At what corresponding refrigerant PSIG?
Old 01-24-18, 02:56 PM
Houston204's Avatar
I have never heard of a corresponding pressure.
Old 01-25-18, 08:25 AM
Geochurchi's Avatar
Received 57 Votes on 53 Posts
What is the issue,is the compressor shutting down what are the symptoms?
Geo
Old 01-25-18, 01:13 PM
A
No issue. Just diagnosing if all the protection switches are in order.
When the water tower (and circulating pump) were down the high pressure limit switch did not trip. We diagnosed and found out it was a working switch but had been bypassed for apparently no reason. What puzzled me is that, even if the limit switch was bypassed, the next line of protection -- the thermal switch inside the compressor -- should have shut the compressor down but it did not. When testing at about 600 PSIG the compressor did go into overload. I cannot tell from that if the thermal switch is good or not. So I asked the pros here.
