Help with new Thermostat
Old 05-05-18, 08:24 PM
A
Hi everyone, Iím installing new thermostat, but Iím confused with the wiring, there is a wire coming from B to W2, how can I connect it with the new thermostat?
here is pictures of both thermostats.
Thank you!
Old 05-06-18, 08:55 PM
user 10's Avatar
Received 45 Votes on 39 Posts
Do you have a heatpump with aux heat or another type of system?
the pictures are small and not clear?
Old 05-07-18, 05:59 AM
A
Yes, it has a secondary heating system, its electrical coils.
Old 05-07-18, 11:00 AM
Received 1,616 Votes on 1,488 Posts
Welcome to the forums.
Turn power off to air handler before messing with the wiring.
We have a problem here. Your White Rodgers stat is showing a B and an O connection. That's telling me that you may have a zoned system in your house. We need confirmation of that. The Honeywell stat you are showing will probably not work there.
Old 05-09-18, 08:12 PM
A
Attachment 93189
Thank you, I’m not sure about if its zoned system or not. By the way, how could tell if its zoned system or not?
also, what type of thermostat or model do you think will fit into my system?
thank you,
