Two Heat pump questions:
Old 05-09-18, 05:09 PM
Question Two Heat pump questions:
An HVAC Installer friend of mind help me design a simple Heat pump for heating water. I have two questions that we cannot answer: 1. Can I put the Evaporator Panels on the bank in front of the house, 25 feet from the Pump, and down about 8 feet..? 2. Do we need a pressure regulator valve that is usually required when the evaporator panels are on the roof..?
Old 05-15-18, 08:31 PM
Houston204's Avatar
Those are not heat pump questions. They are engineering questions.
Are you trying to engineer a geothermal heat pump?
Why not just buy a geothermal heat pump if this is the case?
Old 05-15-18, 09:33 PM
user 10's Avatar
Try an engineering forum - > https://www.reddit.com/r/MechanicalEngineer/
