Outside unit draws more amps in heat mode
Old 10-20-18, 08:59 AM
4
10 yr old Bryant 265ANA048 condenser. When in cool mode unit draws 10.25 amps, when in heat mode 14 amps. Is this something I should be concerned about? Just got a clamp on meter so I've never checked this before.
Old 10-22-18, 08:41 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Probably not an issue but I would still inspect the indoor coil.
The indoor coil serves as the outdoor coil when you place a heat pump into heat mode.
If the indoor coil is dirty it would cause high head pressure in heat mode. This would increase the amperage of your compressor.
