No Heat
Old 11-03-18, 05:36 PM
No Heat
New Honeywell RTH8500D thermostat.
Connections: RC-R-O/B-Y-G-C (right side)
Y2-L-E-AUX W2 (left side)
UL model F+FV060H06B air handler.
Connections: C-O-W1-(W2 nothing connected)-G-Y-R
Need help connecting new thermostat.
Old 11-03-18, 07:35 PM
Welcome to the forums.
A picture of the wiring on the old stat is extremely helpful...... How-to-insert-pictures
A new thermostat also needs to be programmed for its system. Thermostats come defaulted for standard furnace and A/C systems. They must be changed for a heat pump.
Old 11-03-18, 07:53 PM
Don't have old thermostat. A/C works but not heat.
Heat clicks and indicates on but unit does not respond.
Old 11-03-18, 09:02 PM
This is a heat pump...... correct ?
Does it have back up electric heat ?
Did you program the thermostat for heat pump operation ?
You aren't giving me much to help you with.
Old 11-03-18, 09:43 PM
Heat pump unit
It has emergency heat.
I room pic of what I have bit still haven't figured how to upload.
Old 11-03-18, 09:47 PM
I left a link in post 2 for posting pics from a desktop or laptop computer.
Old 11-03-18, 09:50 PM
Heat pump connection
Thank you for your patience and efforts in working with me on this.
I need to know which letter connections on the new thermostat connect to the letters on the air handler. The codes are as listed above.
Old 11-03-18, 09:53 PM
Can I send pics from android
on android not deal top.Can I still send pics from this device.
Old 11-04-18, 03:53 AM
Why are you changing the thermostat? Is it because your heat doesn’t work and your hoping the thermostat was the problem?
Or were you just trying to change the thermostat and now the heat doesn’t work?
Old 11-06-18, 03:49 PM
No heat
Thermostat went bad. Nothing came on. A/C comes on with new thermostat but not heat.
Old 11-06-18, 05:58 PM
C ----------> C
O ----------> O/B
W1 -------> AUX with jumper to E
G ---------> G
Y ----------> Y
R ---------> R/Rc - use jumper provided
In advanced programming........
Function 170 - option 7
Function 180 - option 2
Function 240 - option 9
Function 270 - option 9
