Replacing Janitrol HPT18-60 Thermostat
Old 11-17-18, 09:15 AM
I am trying to replace my old Janitrol Thermostat with an Emerson Sensi Touch Wifi Thermostat. When I installed the new thermostat when in heat mode the heat runs constantly. The set temperature is at 68 but it was still running @ 71. Had to shut off breaker to turn system off. I need help trying to figure this out.
Old 11-17-18, 09:21 AM
The previous post is the old thermostat wiring
Old 11-17-18, 09:24 AM
New Thermostat
Here is a picture of the new thermostat wiring
Old 11-17-18, 09:41 AM
Received 215 Votes on 204 Posts
Welcome to the forums.
Connect white wire to W/E. Tape off the brown wire.
Step 3 ----> HP1
Step 4 ----> EL1
Step 5 ----> O
Old 11-17-18, 10:25 AM
Should the outside unit be running on heat mode?
Old 11-17-18, 11:37 AM
Since changing out the new thermostat my outside unit will not come on. Any suggestions as to what might have happened?
