Furnace blower
Received 0 Votes
Furnace blower
Have a mobile home electric furnace. It turns on and heats fine. When heat cycle is done the blower continues to run. Thermostat is set to auto. The heat will continue to cycle on and off but blower doesnt stop unless u turn the thermostat down, then it will stop. Turn it back up and it will run continuously again
Welcome to the forums.
Electric furnaces use sequencers. A sequencer is a combination time delay and relays in one package. With age they tend to get stuck. Many times it's the heat that gets stuck on.
A model number of the furnace is required to go any further.
If you are considering fixing it yourself..... turn the power off, remove the service cover, shoot and post a few pictures for us. Makes the repair much easier...... How-to-insert-pictures
