Need help reversing Trane air handler Motor
Old 11-26-18, 09:39 PM
i replacesd the blower wheel but had to put the motor on the opposite side because the new wheel was made a little different and the motor shaft wasn’t long enough to install on the side it was on originally. Now I have to reverse the motor direction. Not sure how to do it. It is a capacitor started motor. Any info would be appreciated.
Old 11-26-18, 09:53 PM
Houston204's Avatar
If you have a belt drive or a universal motor then you may have leads that you can change to reverse the rotation of your motor.
If you have a direct acting OEM or an ECM motor you need to get the correct blower wheel.
