Replacing reversing valve solenoid
Old 12-05-18, 11:08 AM
Model CH5524VKA2
Goodman compressor
25 years old
Seems to have a problem going in or coming out of defrost mode intermittently. I shut it down at the thermostat and restart it 5 minutes later and it's ok for a week or more.I thought I'd try to replace the solenoid. Is it just a matter of disconnecting the wires, removing a nut and pulling it out?
Old 12-05-18, 02:17 PM
Hi, as far as I know a solenoid coil is either good or bad , there is no in between , the problem is in the circuit that controls it.
Geo
Old 12-05-18, 05:26 PM
Welcome to the forums.
Yes.... that's all there is to it but I agree with Geo..... those valves don't usually go intermittent.
I'd check the voltage to it first and make sure you aren't loosing that.
Old 12-06-18, 11:02 AM
Great, thank you both. I'll check voltages and probably try a new defrost control board.
