A/C transformer
Old 05-20-19, 11:53 AM
A/C transformer
Is this the transformer?
Pretty warm after i cut off power ..is that normal?
What should it read when testing ?
I replaced that contactor to the right last year ..
Thanks
Old 05-20-19, 12:22 PM
Probably +/- 240vAC on the input/primary side and +/- 24vAC on the output/secondary side.
A transformer can run quite warm and will stay that way for a while after power down.
Old 05-20-19, 02:31 PM
Thanks .
also what are these 2 things ..also looks like under the middle one another transformer.A relay likely in middle one .
looks like a adjuster on the big one .240v..is that a defrost adjust dial? 30-45-90
Ill likely replace it with a goodman in a few months or maybe fall .
Old 05-20-19, 04:20 PM
That looks like a defrost timer in the top picture.
That looks like a fan relay and possibly the compressor contactor in the lower picture.
The fan cycles in defrost mode to keep the head pressure up in the compressor to defrost faster.
It will also cycle if the outside temps get too cold.
Make sure you locate a wiring diagram for that unit before making modifications.
Old 05-20-19, 07:07 PM
This is the contactor ..is that a 2nd one??? Maybe
oddly i wasnt getting power to the compressor on contact end till i hold it down..Im only replacing same parts with updated one for same model.
Its only 8 mo old contactor too.
Is the low pressure switch maybe why compressor doesnt engage unless i hold button in on newer contactor?
Getting pic of 8 mo old contactor
Old 05-20-19, 07:32 PM
That last picture is the actual contactor. I know the left relay is for the fan.
I'm not 100% sure of the purpose of the right one.
Old 05-21-19, 07:13 PM
Here's a better pic ..maybe defrost relay?(old style)
Old 05-21-19, 07:55 PM
I can't tell. I can see the relay but I can't follow the wiring.
Typically all the defrost transfer is done in the timer.
I know one is for the fan.
If you're going to put all this time into this unit..... find a wiring disgram.
Old 05-22-19, 10:16 AM
Yea I went to dealer an got diagrams..its the fan relay..
Parts sure look different today !
Size:  13.2 KB Name:  r4.jpg
Old 05-27-19, 08:34 AM
That red jumper wire on pic earlier ,what looks to be relay, is where the 24 v off transformer "fused wire "ends ..
Does it depend on a signal off wire beside it from defrost unit/board .?
Old 05-27-19, 11:14 AM
I went thru your pictures and resized them. Your were over your 10mb limit. You are now under 1mb.
Post the wiring diagrams again.... full size and I'll tell you what to check for. I'll resize the diagrams after I download them. If it's easier you can send to one of my emails accounts. Let me know.
