Wiring relay /leads
Old 06-01-19, 11:00 AM
T
Wiring relay /leads
I got my replacement defrost /switching relay in finally for my older GE heat pump .
the design has changed 4 times over the years.
This new one in pic shows 2 leads on the end points. Vs 1 an i wanted to know which lead to connect the 2 corner wires to or does it not matter on it ?
Pics show better than i can describe
part # rly00892 230V 5 anp
Im ready to power it up but not till i reconform .
Last pic its hooked up on end leads
Getting pics
Old 06-01-19, 11:18 AM
T
Heres a few pics ..
will send a pic w wired
1st pic shows the 2 ..
looks like they are on same connection but i want to be sure..
Last pic shows it hooked up on end leads ..but it may need to be moved-?
Old 06-01-19, 11:55 AM
T
All i could find was the old diagram pic with 3 leads
Note message...terminal config may be different-message
Looks like 2 yellow. an 2brown white goes to defrost timer [2 yellow]switch an other 2 to defrost board [1 brown 1 white.]
should i keep the 2 leads closeest to other wires or at corner?
Old 06-02-19, 10:13 PM
T
That diagram does apply to this one .
Which pic looks correct ..
1 an 3 wired or 1 an 3 open? .
Im thinking 1st few pics
Old 06-03-19, 12:18 AM
Received 1,167 Votes on 1,082 Posts
I resized and labeled your pictures.
You have the bottom wires on the NC (normally closed) terminals.
You need to move them up to the NO (normally open) terminals.
The first picture in Trotters post are correct.
The third one is what you had shown in your original picture and is incorrect.
Old 06-03-19, 09:26 AM
T
Long story short . Leave 1 an 3 off an keep all 6 wires together[not skipping a row]. As they were in old with 1 an 3 not there [made that way]
4 an 6 ,7 an 9 ,an a an b ..? Correct
STILL CANT LOAD PIC
Old 06-03-19, 01:54 PM
Trotter.....
You need to resize your pictures. You can't post 2-3mb pictures. You only have 10mb storage.
Your 3 pics in post 18 were almost 9mb.
