thermostat wiring not matching up
Old 09-11-19, 05:06 AM
I have a current honeywell connected to G,C,R,Y,W2,E,O replacement thermostat is Trane with inputs of Y2,F,X2,S1,S2,(RC AND R ARE JUMPED),O,Y,G,B
Old 09-11-19, 09:01 AM
Received 340 Votes on 318 Posts
Welcome to the forums.
Post a picture of the current wiring on the thermostat.
Normally W2 isn't used with a heat pump unless that is the standard label.....not the heat pump label.
How-to-insert-pictures.
This is a heat pump system with back up electric heat...... correct ?
Old 09-17-19, 06:55 AM
This is how it is currently wired. I have two of them in my house both wired the same. I would like to replace them with the other thermostat pictured but the letters do not match up.
Old 09-22-19, 07:29 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
Hello LouieC.
Old = New
G = G
C = B
R = R
Y = Y
W2 = W2
O = O
I would tape off that brown wire for E. The new thermostat will energize W2 for Aux heat or emergency heat.
Remember to configure the new thermostat for heat pump operation.
Function 170 = 7.
It would also be a good idea to turn off power to the indoor unit to avoid popping a low voltage fuse or transformer.
Old 09-24-19, 09:40 AM
I wired it just like you suggested. Turned off the breakers to the system. Thermostat turns on. I am able to control the fan (auto,on,circulate) but the system will not turn on. when I put it on heat, cool, auto it will automatically go back to off. There was a single blue wire not attached to old thermostat. so now there is two wires not attached the E and the blue wire. Could any one of those or both be the issue?
Old 09-24-19, 06:58 PM
The brown wire (E) is the old emergency heat wire. It will not affect thermostat operation.
The blue wire was not connected to the old stat so it's just an unneeded/unused spare.
The R - Rc jumper needs to be in place.
I don't know what model of stat you switched to. Does it have an instruction manual ?
It needs to be programmed to your system.
Based on how most stats work..... as long as the stat is powered you can select heat or cool.
You said two of them..... is the other one working ? Possibly bad stat ?
Old 09-25-19, 05:57 PM
These came off a commercial application. They were changed out at a clinic. I was hoping they would work (which I see no reason why they wouldn't)
Both Trane brand one model is 1226 not sure of the other but they are both pictured side by side.
The fan works but the AC itself won't.
E0 code states the thermostat is not communicating with the unit. Not sure how to make them talk to each other.
Any suggestions?
Old 09-25-19, 09:02 PM
A communicating thermostat will not communicate with a standard furnace or A/C. Typically a communicating thermostat is connected with 2-3 wires only.
When I look up Trane 1226 I get a communicating roof mounted system.
I sent a PM to my forum partner. He's more familiar with Trane commercial.
