Heat pump limits?
Heat pump limits?
Would a heat pump be able to get the house temperature to 50 degrees without the use of the built in heat elements if the outside temperature is 25 degrees? Thanks
That is a somewhat strange question. Why would the house be at 50 degrees ?
What temperature are you trying to raise it from ?
Heat pumps have a very slow recovery rate.
So you are asking will a heat pump maintain a house at 50 degrees if 25 degrees outside ?
If this is a location that will be uninhabited..... you'd want electric reheat as a backup in case the heat pump failed.
