Electric bill doubled after new gas furnace install
Old 01-29-20, 11:05 AM
L
We have two systems in a split level house. Heat pump upstairs. Gas furnace downstairs with some ductwork running from downstairs to upstairs. After new gas furnace install, our electric bill has increased a ton. Any suggestions what could cause this and how to fix it?
Thanks!
Old 01-29-20, 11:13 AM
Marq1's Avatar
Received 946 Votes on 859 Posts
Heading says electric, but post says gas increase, which one?
Old 01-29-20, 11:20 AM
T
Received 73 Votes on 67 Posts
Also, is heat pump gas or electric.
Old 01-29-20, 11:23 AM
L
Sorry I fixed my error. Our electric bill increased after install. The heat pump is electric.
Old 01-29-20, 12:05 PM
Received 2,944 Votes on 2,657 Posts
You have a gas furnace downstairs.
You have a heat pump upstairs.
You replaced the gas furnace and the electric bill doubled...... is that correct ?
You should call back the installation company immediately.
A gas furnace draws minimal electricity. It should not have added a large amount of electric usage to the bill.
Old 01-29-20, 01:43 PM
P
Received 1,560 Votes on 1,403 Posts
How are your thermostats set? Is the heat pump running more than it should, shifting the heating load to electric instead of dinosaur farts. Also check the settings for the heat pump. Do you have it manually switched to emergency heat forcing it to use the power hungry heat strips?
Old 01-29-20, 05:38 PM
L
Thanks, I did schedule the installers to come back out. The thermostats are set correctly. The heat pump for some reason is working overtime.
We did a large comparison of our daily electric charge from comparing last December and January to this year. So we compared last year's daily electric charge from our electric company and this year's daily charge. We then compared these charges based on the daily temperature so we could compare correctly. The daily electric charges are 50% higher every single day in our comparisons after the furnace was installed. We need to figure out why our heat pump is working overtime.
Old 01-29-20, 06:36 PM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
Most likely your heat strips are coming on. they do come on during defrost mode. this is time and temp based. If its below 32 f they will come on every 30,60,90,120min depending on what the installer set it too.
Also your t stat can be wired wrong and the heat strips may be activated.
Also settings in the t stat need to be changed. usually the t stats are set that if you set the t stat 2 degrees past set point the strips will come on to warm the home faster.
let us know...
Old 01-29-20, 06:47 PM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
What did the new furnace replace? almost sounds like you are loosing heat to the second floor, what else has changed since the new install?
Geo
Old 01-29-20, 07:33 PM
I'm still a little vague here.......
The heat pump was existing and should not have changed.
The gas furnace was replaced.
Old 01-30-20, 10:31 AM
L
The gas furnace replaced an older gas furnace. We did not have any issues with the heat pump until the new furnace was installed. All our electric bill increased after the install. For some reason the new furnace doesn't seem to be helping the heat pump. There's always a chance something went wrong with the heat pump around the install time that is just coincidental, but I hope not.
Old 01-30-20, 10:55 AM
H
Received 250 Votes on 216 Posts
Quick guess - the new gas furnace is a "smart" furnace which is set to "sample" the temperature, i.e. it runs the fan for ~10 minutes to circulate the air check air temperature to determine whether it need to ignite.
Circulating the air ends up triggering the heat pump. Seems like the heat pump is either set to emergency heat and uses electric, OR the heat pump is on some "instant heat" setting so it engages the electric heat strips for immediate heat while the heat pump comes on.
Old 01-30-20, 08:13 PM
A
Received 214 Votes on 197 Posts
For test purposes lasting perhaps a week while you continue to measure electricity usage...
Do the strip heaters (auxiliary heaters; emergency heaters) that go with the heat pump have their own circuit breakers? Try flipping those breakers off, letting the heat pump system rely only on the heat pump itself.
Another test, to be done in a different week
Turn the heat pump strip breakers back on. Turn up the gas furnace thermostat a few degrees so the gas furnace starts sooner and runs longer than the heat pump. Again, measure electricity usage.
Old 01-30-20, 09:01 PM
lawrosa's Avatar
Super Moderator
A clamp on amp meter at the disconnect will tell you if the strips are coming on. easy to test..
High voltage though.. You have the techs coming out so let them do it...
let us know. we are all curious..
