Lennox to honeywell thermostat
Old 03-31-20, 12:38 PM
L
Im trying to replace an older lennox thermostat T874R1178 24F5601with a honeywell RTH 2300B
https://www.dropbox.com/s/lqwg8xzggk64mlw/2020-03-31%2013.01.51.jpg?dl=0
https://www.dropbox.com/s/zbcjw8x9v2tc2go/2020-03-31%2013.01.44.jpg?dl=0
https://www.dropbox.com/s/y6m18n3qv1rhjzw/2020-03-31%2013.02.05.jpg?dl=0
Old
R
Y
X
F
V
VR
E
L
A
NEW
B
O
G
Y
W
R
RC
What wires should go to what terminal? Thanks in advance!
Old 03-31-20, 01:00 PM
Received 756 Votes on 710 Posts
Welcome to the forums.
There is no guessing.
We need the model number of the old stat as well as the new Honeywell one.
We prefer a picture of the old thermostat base to see the actual colors on which terminals.
How-to-insert-pictures.
Old 03-31-20, 01:23 PM
L
I added links for the pictures and added the model numbers
Old 03-31-20, 01:28 PM
L
Pictures uploaded
Pictures for thermostat thanks
Old 03-31-20, 01:36 PM
Ok.... I see the wiring one I needed. Working on the diagram.
To confirm...... this is a heat pump system with back up electric heating ?
If yes..... that thermostat won't work. It doesn't support back up heating.
Old 03-31-20, 01:46 PM
L
It's electric forced air furnace with ac. No heat pumps...
Old 03-31-20, 02:53 PM
Ok.... thanks.
X -------> yellow -----> C
F -------> green ------> G
V -------> blue
Vr ------> red
E -------> white --------> W
L --------> white
A -------> blue
I've got some problems doing the transpositioning. Since there are two whites and two blue wires.... that would indicate two cables. I need that confirmed. There are two different wires on V and Vr... that's also strange.
You may need to confirm wiring at the air handler also.
Old 03-31-20, 03:47 PM
L
Yes there are two cables feeding the thermostat
My guess at wiring the new thermostat is as follows
NEW------OLD
B---??
O---??
G--F
Y--M
W--Y
R--VR
RC-R
On the old one i still don't know what to do with wires X E L A
Thanks !
Old 03-31-20, 05:12 PM
You don't have Y or M used on the old stat.
A and L would not normally be needed.
You should only have one 24v R wire.
It is possible the V is common and Vr is 24vAC.
Name:  Q674L-1355 - Copy.jpg
Old 04-01-20, 06:52 AM
Geochurchi's Avatar
Received 37 Votes on 35 Posts
Hi, this pic may be of some help.
https://www.manualslib.com/manual/55...t.html?page=83
you may have to sort through this link for the Lennox unit.
Geo
Old 04-02-20, 07:31 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
https://www.doityourself.com/forum/t...l-rth6450.html
Looks like V and Vr is the same as Rc and R.
The strangest part is that M is the compressor "Y" and R is the reversing valve "O".
