Troubleshooting GSH130481AD Goodman condenser
Old 04-23-20, 04:41 AM
Question about troubleshooting a Outdoor Condensing Unit (Goodman Heat-pump GSH130481AD).
Based on the description below, any suggestion about the next components I should check?
(I have attached a picture of the unit label, and was going to attach a PDF of the Manual, however it was too large, I found it here manualslib.com/download/867424/Goodman-Gsh-Series.html)
Thanks for the help; any suggestions are appreciated!!
Symptoms:
  • Outdoor unit will not heat or cool
  • Outdoor fan does not turn on
  • There is slight quiet "hum/buzz" from inside the unit when in heating or cooling mode
More Details / Tests:
Heating:
  • Indoor AHU fan comes on, thermostat says heating or heating aux
  • Heating aux seems to work some
  • Outdoor CU fan does not come on, slight buzz/hum from inside unit
  • Outdoor CU fan does not "kick-start" (using a thin stick pushing fan manually) but the blades spin very freely in both directions
Cooling:
  • Indoor AHU fan comes on, thermostat says cooling
Off: (heating with house above setpoint)
  • Indoor AHU fan off, thermostat says "heat set to"
  • Outdoor unit NO hum/buzz
Unit Details:
Goodman GSH130481AD
  • Volts: 208/230
  • Phase: 1
  • Hertz: 60
  • Voltage Range: Min.: 197 Max.: 253
  • Max. Fuse Amps or Max. Circuit Breaker: 40
  • Min. Citcuit Amps: 23.9
  • Fan Motor: FLA: 1.50; HP: 1/4; RLA: 17.9; LRA: 104
  • Factory Test Pressure PSIG: LOW: 150; HIGH: 300
Old 04-23-20, 10:29 AM
Received 3,480 Upvotes on 3,125 Posts
Welcome to the forums.
Assuming you have a meter as you will need one.
Carefully check for 240vAC on the supply lines to the contactor first.
Most heat pump systems are wired similarly.........
R - red - 24vAC always live power
O - orange - 24vAC for reversing valve
C - ?? color - Common
Y - yellow - 24vAC contactor
W - white - electric heat during defrost
It looks like your unit should have a diagnostic module. Turn the power off to the condenser.
Remove the wiring access cover. Turn power back on. Look for the LEDs on the monitor.
mikemcclinto voted this post useful.
Old 04-25-20, 12:40 PM
Thanks PJmax.
​​​​​I will check that next.
Some more info on what I have checked:
I started with removing and checking the dual run capacitor, the capacitance looks correct for both fan and and condenser.
Thanks again, this is a great resource.
Old 04-25-20, 01:47 PM
You should have 24vAC between R and C.
You should also have 24vAC between Y and C on a call for cooling.
You should also have 24vAC between O and C.
Old 04-25-20, 02:44 PM
Thanks Pete,
Took some measurements with power to the unit.
- Had 248V supply to the contactor
- Confirmed that it was the contactor that was buzzing (on both call for heating and call for cooling)
-- Contactor did not make noise when Thermostat Set-point was satisfied (no call heating or cooling)
- Noticed the contactor did not look in good shape (see top terminal in pictures)
- Poked around a little with the meter on the other end of the contactor, and did not get any readings for voltage (I am not confident I was checking the right components)
Hoping I didn't jump the gun, but I removed the contactor and am planning to try to find a replacement (my go-to method would be using the label, but in the pictures you can see it is pretty damaged).
From the manual I think I need to replace CONT1P030024VS Contactor (for M22 GSH130481AD).
Found this one on amazon: https://www.amazon.com/OneTrip-Parts.../dp/B007YSH48M
Last edited by mikemcclinto; 04-25-20 at 02:55 PM. Reason: duplicate images and extra info about possible replacement
Old 04-25-20, 03:16 PM
Was the contactor being pulled in ?
Did you check for 24vAC on the contactor coil terminals (yellow and blue wires) ?
That contactor should be a replacement for yours.
Contactors come in two major types..... single pole switching and the other pole has a jumper OR two switching contacts. That style needs to be maintained.
Old 04-28-20, 01:06 PM
Replacing the contactor did the trick. Thanks for all the help!
