Trane packaged unit WiFi thermostat wiring help
Received 0 Votes
I have a Trane gas heat/ electric cooling packaged unit (4YYC4048A1090A) but am confused by the thermostat wiring. I'm trying to upgrade to a WiFi thermostat that needs a C wire which I currently don't have for my "dumb" thermostat.
Looking at the HVAC end, it seems like I have a Y, W, G, R, B wires coming out of the brown wiring (pic 1) sheath that runs out of the HVAC unit. The blue appears to be spliced for the 24v common wiring. However, the wire colors at the thermostat in my house are completely different colors, with no B wire running from the wall. Is there something simple I am missing to make sense of this?
Thanks for any help
Thanks for any help
Welcome to the forums.
At your thermostat I see four t'stat wires white, red, green, yellow.
That brown and dark green do not end up at the rooftop unit.
The wires at the thermostat don't match the wires at the rooftop unit. There is a splice somewhere in between as the cables are two different types.
Heavy wire ...........T'Stat wire
White -----------------> white -------------> W
Green ----------------> green ------------> G
Yellow ----------------> yellow ------------> Y
Red -------------------> red ----------------> R
Blue ------------------> blue ---------------> C
