heat pump outside unit not running
#41
Received 0 Votes
so a local ac guy came out and said he couldnt test the pressure without the unit running. Is that true? Kind of made sense but then how do you know if its the charge or a faulty low pressure switch?
At least he didnt charge for the visit.
#42
Received 0 Votes
So a local ac guy came out. Said he could not test pressure without the unit running. Is that true? Kind of made sense, but how do you determine if it is the charge or a faulty low pressure switch?
At least $0.00 for the visit
#43
No, it’s not.
He should’ve been able to check if there was standing pressure in the system and if the pressure switch was open or closed.
You’ll still have to have a tech check the unit.
He had nothing to say about why the unit wasn’t working?
