Advice on placement of heat pump indoor unit?
Old 09-15-20, 08:36 PM
R
The room is 13.5 x 13.5. The heat pump is 9000 btu. Where should I place the heating/cooling unit in relation to where I usually sit? Without the heat pump, I have used an oil filled electric heater which I found needed to be pretty close to me to keep me warm. But I am assuming the 9000 btus will be sufficient to fill the entire room, which is well insulated. So from that I am thinking of placing the unit in the wall farthest from where I sit, so that I do not have hot or cold hitting me directly.
But I would hate to end up needing the electric radiator in addition to the heat pump.
In general, what are the rules for placing the indoor unit of a mini-split 9000 btu in a room for maximum comfort?
Old 09-16-20, 01:04 AM
ferd42's Avatar
Received 17 Votes on 17 Posts
It should go on an outside wall, above a window if possible. The mini-split will have some adjustment to direction(s) of discharge, if there are draft issues.
Will 9,000 BTUH be enough? New 2,500 SF homes in an 18F climate (ASHRAE 99% value for Dover, Delaware) have a heat loss around 20,000 BTUH. On that basis, 9,000 is enough to heat around 1,125 SF (six times your 182 SF), so you should be OK in an older home in a colder climate.
Oil-filled heaters are often 1,500 watts, 5,120 BTUH. You're increasing that by 75% AND adding the ability to blend the air in the room to establish a more uniform temperature distribution. Enjoy!
Old 09-30-20, 06:25 PM
R
Very encouraging. I have been dragging my feet on this project for no rational reason. I have the cement pad poured and the conduit and fuse box installed, with no wire yet.
Above the window will definitely be possible, with much depending on the length of the coolant line, since of course I am leaving it stock.
For cooling comparison, I do have a 15000 btu unit in another part of the house which would probably cover the whole house 800 sq ft if left on. I never use it because it is on the same breaker as the smaller one, so blows fuses. It should have had a dedicated wire. It would cool that phalf of the house pretty quickly.
