Turn ptac off or down at night
Received 0 Votes
We have a 4 season room with a separate ptac (heat pump with electric strip backup version) unit. The room is used of and on throughout the day from 8a to 8p time frame but normally we will not be in it at all the other 12 hours.
during that time Is it more cost effective to turn the unit off or to set it back to the minimum heat setting of 58 degrees, knowing that we will turn it up to about 66 in the morning
It depends on how high an electric bill you want.
A heat pump takes hours to supply heat. It operates slow and steady.
It doesn't respond well to setbacks.
When the room temperature is 3° or more degrees under the set temperature.... the electric reheat coils are energized along with the heat pump to recover faster. The electric elements use a lot more electricity than the heat pump does making setback not always cost effective.
