Air handler on 24/7
Old 06-03-23, 01:27 PM
Z
Air handler on 24/7
Just got a new Moovair heat pump and air handler installed. I’m waiting for a new thermostat as the one they installed is not what I ordered.
in any event, I’ve been told by others on online forums that this unit’s air handler will run 24/7 when in “auto” or “cool” mode.
does that make sense? Does this occur with other manufacturers?
Old 06-03-23, 01:50 PM
Received 3,593 Upvotes on 3,222 Posts
An air handler running continuously in the AUTO mode pretty much defeats the purpose of a thermostat.
Most air handlers only run on a call for heating or cooling.
Fan On is reserved for continuous operation.
You could post the air handler model number and I can check further.
Old 06-03-23, 01:57 PM
Z
Thanks. That’s what I thought.
FMA36HIAHUU230X7
Old 06-03-23, 02:04 PM
Z
I will say that the outdoor fan turns on and off as needed but the air handler runs 24/7 and as I mentioned another user online said the same thing.
Old 06-03-23, 02:13 PM
I have to check further when I get back to the shop.
I did read...... auto mode is constantly variable for maximum efficiency.
Old 06-03-23, 10:29 PM
Houston204's Avatar
Received 87 Upvotes on 80 Posts
A continuously running fan is commonly found with mini splits. They get to claim higher SEER ratings this way.
Sadly this will promote the growth of mold in the air handler.
I recommend adding a UV light.
