Sound Deadening Ideas
Our church has a large activity center for basketball, volleyball, dinners, etc. When constructed about 10 years ago, we installed some large acoustic Styrofoam panels around the room to absorb the excess noise. They work reasonably well, but we would still like to absorb more of the noise.
Those panels are now dirty and some are damaged from the sports activity and require replacing. What other options are available to reduce the noise that may have come on the market since we constructed the facility?
Thanks.
Thanks.
thanks for your question..........i've been waiting to see if someone could come up with any ideas for you, but i see they haven't. and i don't either. i would suggest that you get a hold of the company that built your building, or a similar commercial construction company, and see if they have any up-to-date information for you.
Received 1 Upvote
1 Post
You dont say what the wall is there are what you can do.
For a sound wall you lay out the wall on 2X6 plates and use 2X4 stud's stager them 16" on center side to side then weave unface insulation in the stud's. This would be for all inside walls. Like room to room
ED
ED
Do you want to stop sound from travelling through the walls, or stop it from bouncing around in the room? Different problem; different solution. If the existing styrofoam is smooth-faced, it will do little to deaden noise inside the room itself.
Sound Absorbing Panels
I just installed some large (one was 4x8 feet) "acoustic panels" in a large echoey office
They work wonders
These are sound absorbing panels covered in an "acoustically transparent fabric" that you can attach to the walls (or ceilings)
Check out www.acousticsfirst.com
You'll see they do everything but look for Respond Panels
They work wonders
