Touch lamp
Touch lamp
I have a brand new touch lamp that worked for about an hour. Now when I touch it it no longer turns on or off by the touch. I have to unplug it from the wall to turn it off and on. What might I have done to it?
Thanks
Thanks
No other thoughts? It is in rental property, and when I had a chance to take it back in, I didn't. Now I no longer have the box, but still the same problem. Just thought someone might know something about the "touch" style lamp and why it might not work by touch anymore.
I have several touch lamps and one thing that seems to be hard on mine is if a bulb burns out.
This seems to damage the circuitry.
Also, if you are in a cold climate and have a dry house, sparks from your fingers could damage it as well as possibly using a bulb that is a higher wattage than recommended.
Other than this it likely was defective and many places will accept returns without the packaging.
Opps, my mistake.
I should have known better to not suggest a compact fluorescent lamp as a cause of your problem.
Yes, the bulb you used would cause a problem.
A touch lamp works the same way as a dimmer which also can not control a standard compact fluorescent bulb.
Will it work on a regular bulb?
Small electrical surges will turn them on and off, too. For instance, as my wife irons her nursing uniforms, the iron will turn on and off to keep a stable temperature. I noticed as the iron cycled it affected the lamp closest to it, probably on the same circuit. If your humidity is low, try licking your finger before you touch it. Sometimes the conductivity in dry areas needs a boost.
