hardware for dresser
Old 06-24-00, 10:55 AM
Guest
Post
Can anyone tell me where to get catalogs or info on hardware for a dresser? Home Depot only carries stuff for cupboards and drawers, and as this is an old handmade dresser, I have the feeling the size of the pulls I need will be hard to find. You may email me also at SHall79420@aol.com. Thanks!
Old 07-08-00, 02:37 PM
Guest
Wink
You will need the following information: 1. If your hardware has two holes for attachment you will need the distance center to center for the holes. 2. The thickness of the wood you are mounting on. 3. If there was a decorative backing plate that has left an outline you will need size and outline to be able to cover it. Try: 1. Renovator's Supply, Box 2515, Conway, NH 03818 1-800-659-2211. 2.www.oldhousejournal.com 3.www.tias.com 4. www.oldtyme.com Also, you can check ads in Colonial Homes, Early
American Homes, Traditional Homes, Country Living, and This Old House magazines for sources.
Old 08-14-00, 09:29 PM
Guest
Lightbulb
If you have any "Antique" malls or junk shops near you, they usually have boxes of old hardware for dressers. Depending on what you're looking for and quanity, prices vary. I found several for a friend in the same situation.
