Best Method to "Mount/Stick" Electric Cord Against Wall?
Old 11-04-16, 10:44 PM
I have two large counter space areas on either side of the sink in my kitchen, however only one side has an outlet. To put an outlet on the other side, since I'm in an apartment and can't install a new outlet, I was advised to plug in a power strip, and run the cord against the wall from one side to the other. It's only about 4 feet. Then mount the power strip on the other wall.
Question 1: what is the best way to "mount" or "stick" the cord against the wall?
Question 2: What is the best way to mount the power strip? With nails in the wall, slotted into the mount holes on the strip?
Old 11-05-16, 12:32 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
So you would be installing an extension cord behind a sink?
Old 11-05-16, 04:47 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
This is an extension of this thread http://www.doityourself.com/forum/el...ml#post2574588
Look into Command products. They stick well and can be removed without damage to the walls.
