Which fastener for clothing rod
Old 05-01-20, 12:33 PM
Received 1 Upvote on 1 Post
Question Which fastener for clothing rod
I'm installing a clothes hanging rod on a concrete wall. Instructions say to use anchors to hang the rod. Probably not the best on a concrete wall. Should I use tapcon screws? They wouldn't look as nice but if they worked . . . .
Suggestions?
Thanks so much
Mary
Old 05-01-20, 01:20 PM
Received 4,154 Upvotes on 3,730 Posts
I'm assuming you are talking about mounting the side cups that the rod sits in ?
If yes..... it makes no difference what you use. Plastic anchors are fine. There is no problem with the cups getting pulled away from the wall. Fastener shear is the only issue.
Old 05-01-20, 03:01 PM
Here's the shelf
It's an IKEA item.
I guess I thought you didn't use anchors in concrete
Old 05-01-20, 03:39 PM
P
Received 2,326 Upvotes on 2,068 Posts
For a rod like that you will have to drill and fasten it into the concrete. I like plastic mollies and screws. One big reason is you can use stainless steel screws and even find something with a sorta attractive head. Tapcons always look like Tapcons. An OK look on a construction sight but not the sort of thing I want to see on the wall in my bathroom.
Old 05-02-20, 02:04 AM
Received 875 Upvotes on 766 Posts
Are you sure that's a concrete wall? it appears to be an interior wall.
Old 05-02-20, 03:01 PM
Yes. I'm sure. This room was added to the house after the fact.
Old 05-03-20, 03:57 AM
Ok, if I were to use tap cons I'd paint the heads white.
Old 05-04-20, 04:08 PM
Good thought. I ended up asking the guy next door. Somehow he got it installed.
